Hooking up MEP002 to my house
Chainbreaker
2,111
Oregon
You will need a 1/2" socket (IIRC) to remove the nut on the back side of the genset frame gnd. lug. Pull off the L0 wire, be sure to reinstall the nut back on gnd lug, and then insulate the end of L0 wire with a few wraps of electrical tape. If you don't know where LO is located take a look at my post #3 in the other thread you started regarding grounding: https://www.steelsoldiers.com/showthread.php?172522-Mep002-proper-grounding
The sticky I referred you to, in post #3, has the LO wire identified in one of the photo's if you're not sure which wire it is.
