Link belt 750
- 7
- 3
- Carson city
Does anyone knows where to find the part on the steering column that the horn wires plug into. I’m going to assume that it is a relay of some sort.
What's the problem your trying to fix with the horn.Does anyone knows where to find the part on the steering column that the horn wires plug into. I’m going to assume that it is a relay of some sort.
Just curious, did you try turning on the brake lights using the 3 position light switch? I know my truck does not enable the horn if the light switch is off.
Exactly that's what I was thinking too. But it would be nice to find out what his problem isJust curious, did you try turning on the brake lights using the 3 position light switch? I know my truck does not enable the horn if the light switch is off.
Thanks for the responses. Update I was missing the brush that mounts on the steering column tube. I found a horn repair kit on eBay and now the thing toots like it should.Does anyone knows where to find the part on the steering column that the horn wires plug into. I’m going to assume that it is a relay of some sort.
