Horn sounds when fuse inserted and
edpdx
73
Oregon
Did the searches on this forum and tracked down the Diode on the rear of the horn relay near the fuse block. I use to know how to read IC; but don't remember now. What diode is used here. I hate to just cut it out. I'll make up a diode with two leads and use parasite splices to tie the new one in and snip the old one out. I have some before shots, I just need the diode to get back up and running. Will post after... after.
Ed
edpdx
73
Oregon
bigburb11, HUH? Man I'm stoked to hear this... I think?!? What exactly did you get? What do I ask for:
relay with the diode integrated IIRC
Is there another thread discussing this? Do you know the part number. Do tell.
bigburb11
Detroit, MI
Well. I went to NAPA and asked for a horn relay for an 84K30. I cut the diode out of the factory harness. Works fine. I believe the schematic on the relay showed the diode in the circuit... it would be easy to incorporate that into the "black box" that is the relay... I can take a look at the relay tomorrow when I'm home if you want.
