Horn trouble
69DeuceJuice
81
North Carolina
The solenoid on my horn isn’t stuck closed it operates properly but as soon as you touch the wires together to connect the horn to power it clicks the solenoid even without pressing the horn button. How does this circuit work is it always hot and the horn button closes the ground or is it the other way around? Is it common that the horn button will make this issue occur and taking it apart and cleaning it is the solution?
69DeuceJuice
81
North Carolina
Or an exposed wire inside the steering column closes the ground. Trace the wire from the horn all the way to the steering column and make sure there are no faults there. Next step is to replace the wire inside the steering column.
I believe this is my problem because when I pulled the horn button itself out the wire was pulled down inside the steering column and I had to pull it up and even then the connector only came out of the column about an inch before it got tight. I put everything back together and the horn worked fine. When I went to drive off though and turned my steering wheel a couple times the horn suddenly went off and when I turned my wheel back it cut off so it’s grounding itself inside the steering column i think. Problem is I’m new to these trucks and have no clue where that wire come out of the steering column. How does the wire inside the steering column not get twisted up, is there some sort of brushed ring connection that allows it to spin without linking the wire? Any photos or videos even links to YouTube videos would be very helpful. Thank you all
SCSG-G4
PSVB 3003
5,399
3,490
Lexington, South Carolina
The wire comes out the bottom of the shaft on the front of the steering gear. The wire that goes up in the shaft has a seal on the bottom. Try to trace the wire from the horn across the engine compartment over to the bottom of the steering column and you will find it. The -24, -24&P manuals will have the parts and procedure for fixing it.
NY Tom
848
Riverhead, NY
Comes out of the front of the steering box behind the radiator. There is a little cone shaped rubber plug the wire passes thru there. It is simple design but not a great one. I believe the wire just twists a bit inside the column as you turn the wheel. But if installed with wheels straight ahead there is a limit to how much it has to twist in each direction.
Modiconman
31
Richmond, VA
There is a "slip ring" and "brush" that is on the steering shaft. That provides the connection up to the horn button. I had to replace all of those pieces on mine when it started doing the same thing. I had to pull the steering wheel and the steering shaft out to get to it all. Big mikes motor pool had all of the replacement parts. a bit of a PITA to do, but not difficult.
