Hose to air intake and random wire ID
Pstyckiewicz
62
Massachusetts
I am looking to identify a loose hose near the front differential. I traced it back to where the air filter housing is, but I’m not sure what it hooks up to down near the front diff. In addition I found a green wire that is cut. Not sure if anyone can help me figure out where theses things go. Also I have a few random parts that were in the truck that I don’t know what they are.
thanks,
  • Like
Reactions: OBX
mgFray
909
Southern Minnesota
Below the green in the first picture is the hose for the washer nozzle.. (there should be one on each side in front of the windows).. Other then that, I'm not sure. Sorry.
Pstyckiewicz
62
Massachusetts
Thanks for the reply’s. It is a USMC truck. I have the black cup, but they cut it up. I was wondering where that would mount to. As for the green wire it looks to be a grounding wire. I’ll have to keep looking for where it might have gone to. It is an M1152A1 so who knows what they were running in this thing.
Gcelevator
537
Florida USA
Whatvkind of AC compressor do you have? Does it have a green wife attached or a screew to the body were a connector might attach? Mine has a green wire attached to it not sure if it is the same.
Mainsail
1,441
Puget Sound, WA
My M1165 has the same hose shown in the second picture. The clamp should be holding some sort of plug or valve at the opening of the line. I guessed it might be a pressure relief/check valve arrangement for the fording system.
Mogman
8,292
Papalote, TX
Have you replaced the missing CDR valve? if not you have an open path into your intake, any debris gets in there you will be looking for another engine
