How did you get your bed off.
197thhhc
15
Williamsburg, OHIO
This question is for the schmo who does'nt have a crane, forklift, loader, etc. I want to hear the stories from the guys with a hammer and a tree. The real manual labor guys. Someone who did it in their apartment buildings parking lot (just kidding, but that would be a cool story.) I will be taking mine off this weekend and will post pictures. Until then I want to see your stories and pics.:grd:
Billy Bobbed
13
Terre Haute,Indiana
I cut all the bolts but two.Drove it to the scrap yard.They cut the two bolts off and used a magnet,and I got $40.00 for it.I think I got screwed.
Ridgerunner
Holland, Mi
I took all the bolts out that held the box to the frame, chained it to the M104 trailer that I had in the yard, then drove the Deuce out from under it. It make a nice "thud" when it hits the ground.
flyxpl
9
Chatham IL
That is how I get boats off of trailers , put a few old tires on the ground for it to fall on .
wreckerman893
Possum Connoisseur
15,623
2,027
When I removed the bed off my bobber I jacked it up and put some big industrial rollers between the bed and the frame.....I then pulled it backward with my little tractor onto some 4x4s that I had jacked up on the aforementioned 55 gallon drums. I had to keep moving the rollers untill I had it where I wanted it.
You have to make sure nothing catches and pulls the drums over while you are moving the bed along the 4x4s. I think I filled them with water for ballast.
The mudflaps and pioneer tool rack have to be removed prior to this operation.
If you don't have a big air wrench the best way to remove the mounting bolts is the "Blue Flame Speed Wrench".
KsM715
142
St George Ks
When pulling it straight off the back make sure your air tanks dont have the pressure relief sticking straight up or you'll bust it off. Ask me how I know. Notice mine is now in a 90 fitting.
tm america
23
merrillville in
what kind of shape is it in and what type of bed if its in decent shape i would remove it for you free and give you scrap price for it ..if it is a m109 bed i would deffinately be interested and would probably even drive out to your place to take it off for you.other wise chain it to a tre and drive the truck out from under it
Barrman
1,720
Giddings, Texas
4 55 gallon drums, 4 4" fence post, 4 jack stands and 1 hi lift jack. Stick the fence post under the edge of the bed but above the bed frame. Use the hi-lift to pick up the post, use the jack stand on top of the drum to hold it however high you want and move on to the other 3 corners. Drive the truck away.
I have done this 3 or 4 times now. Works great. Just be sure you have flat land to do it on. A slight incline and things can get dangerous.
USAFSS-ColdWarrior
Chaplain
5,724
The full story of our bed RECOVERY is in the link below. Sorry, no help on removal. Just a caution.....
If you live in RATTLESNAKE COUNTRY - BE VERY CAREFUL !
When we lifted the bed, there were THREE RATTLERS under it after sitting on the ground for a few weeks.
1,807
Re-installed a SECM bed on a Dodge M887 at Wayne Harris house. Used blocks, long 4x4s and a coule of bumper jacks. Was laborious but successful. You should see how I pull engines out of deuce wreckers.
littlebob
26
Baton Rouge LA
I did something similar to wreckerman and did what KsM715 did. Just make your sure you have a way to handle it afterward. I jacked one side up at a time and used blocks to hold up. After both sides were up I put short peices of pipe under it and let it back down on the pipe. I then put the long bolts from the front at all corners to manuver to where I wanted to drop it. Once in position, I but some old tires to break the fall I just pushed/rolled it back till the back fell ont the tires the drove foward anplaced more tires. Barrmans drum idea would have worked better, but I didn't have any.
