how do u hook up a power inverter to your humvee
rookie
portcharlotte fl
I want to know how do u hook up a power inverter its a 24 volt to 110 i want to know how to safely hook it up i have a 94 hmmvw it also has a 200 amp alternator.
rookie
portcharlotte fl
How would u hook up a 24 volt power inverter without the slave port to one battery or ? I saw the one one u said jake but its a bit pricey nice and convenient thou.
gimpyrobb
dumpsterlandingfromorbit!
27,785
747
Cincy Ohio
If its 24v, one battery will not get the job done.
Hook the positive lead to the + side of one battery and the negative lead to the - of the other battery. Make sure you put a fuse within a couple inches of the + connection of the appropriate size for your protection.
dmetalmiki
2,026
London England
As mentioned, Inverter positive+ to the 24 volt positive Power out on the vehicles first battery, and Inverter negative to the (second) battery negative. Make sure and use a good quality heavy duty wiring for the job.
Fit a separate idolator switch, and a suitable fuse.
papakb
1,186
San Jose, Ca
Remember that inverters are power suckers and can kill your batteries pretty quickly if left on with the engine off. Depending on the inverter you buy, make sure that you input feed wires match the manufacturers recommendations for current capacity. The last thing you want is an electrical fire in your truck. You might want to consider something called a battery tender that will disconnect power before the voltage gets too low to start the truck.
Kurt
KG6KMJ
