How do you know if the vehicle has an EUC?
2,761
Is there a way of finding out if a vehicle has an EUC on it? The CUCV that a friend of mine is looking at has been is civi hands for a while and the current owner does not know if there might be an EUC on it. He wants to export it to NZ.
Thanks, Will
papercu
31
Baxley, Ga.
enc
Any item with a demill code of G or Q will require a EUC. The CUCV will require one.
There places where you can buy one without a EUC but for export I'll bet someone will ask to see it.
The requirements may change but they do not expire. Wayne
2,761
RE: enc
So, does that mean, that if the vehicle was purchased prior to the EUC thing...5 or 6 years ago...the original owner might have rec'd a notice that he needed to fill out the EUC when the EUC requirement started? If the original owner did get the notice, filled it out, or, sold it before he got the notice stating he needed to fill out the EUC, what would happen then? Is there a resource available to us, that can find this info out? How about theregistration numbers..assuming that the original numbers are still on the truck or it has the original dataplates.
papercu
31
Baxley, Ga.
EUC
I don't know the year the ECU started but it is more than 5 or 6 years ago. I started buying military trucks about 1993 and it was a requiement back then on trucks sold on the national sales.
They use the NSN to ID and the way I understand it ANYTIME a NSN is added to the Demil list it applies to all the item with that number and wouldn't matter if it was sold without a EUC the first time.
m16ty
218
Dickson,TN
I don't know for sure but I think that even if the item was bought from the Gov. before EUCs were required you'll have to have approval on the item (if they require EUC now said item) before you can export. When the demil code changed it not only applied to future auctions but to any and all items (even in private hands) affected by the code change.
Michael
24
Fulton, MS
I have bought CUCVs before and after the EUC thing on them. The change on cucvs was only recently. I have not been asked for an EUC to be filled out on the ones I bought before the change, ... yet. Papercu must be thinking about M35s, they have needed one for a long time. You can look up the NSN number and it will give you the current demil status. I don't think it makes any difference if an EUC was filled out or not about it being illegal to export something on the list.
