shadow
- 1
- 18
- Cedar Rapids, Iowa
I have a question about how to properly drive a manual.
I was thinking back to when I moved my deuce tractor, M275, and I had problems where every time I up shifted, the transfer lever would pop out of gear so I had to follow steps like: push clutch, pull out of gear, put into next gear, hold clutch still, hold transfer case lever up, and then release clutch. I am not skilled at driving a manual and only had like 3 or 4 hours in a buddies dump truck years before I got the deuce so I was fumbling my way through it. I had all kinds of problems down shifting. I remembered on his dump truck that you could bump the gas and rev up to shift down but that didn’t work at all for me when I tried it in the tractor. I even tried shifting down while holding the transfer case lever but almost every time I would get stuck in neutral with the transmission and could not get back into gear until I was at a full stop. I ended up using the brakes only to slow down. Meaning I would push the clutch in and use the brakes to slow and stop. Then I could up shift like before.
Is it normal to get stuck in neutral? Is it bad on the transmission to not down shift? I can imagine how hard it might be on the brake shoes. When I got to where I was going, about 8 miles away, there was smoke coming from one side of the rear axles. I assumed it was from a brake but I am wondering now if I didn’t have any fluid in the axle. It smelled like burning metal like when you torch cut something but I figured maybe the brakes shoes where too hot. I read the post a little bit ago where the member said to check all fluids because a truck he got was missing fluid in the axle. I really really hope it was just the shoe smoking and not something in the axle. There was a faint blue smoke coming from around the break area by that tire.
Hey JOEC, Itried driving like that and I lost an EAR when I tried to Clutch with it!!LOL
