How do you remove the Hydroboot mount square nut see picture
M1028A1ShelterCarrier
68
Mammoth Lakes Ca.
M1008 square nut. I cannot remove this tight 4 sided nut and I am out of ideas. A crecent wrench, deep socket (because of the non removable rod) and a punch have failed to do it. I need an idea so I can get it off and place the mount on the new boost. Thanks
Stretch44875
Super Jr. Moderator
29
Tiro, Ohio
If the hydro unit can spin in the plate, maybe put the plate in a vise and turn the hydro with a pipe wrench, instead of the nut? Might break it loose for you.
Dennis
gasser
Ocean Springs, MS
M1028A1ShelterCarrier,
To be clear - are you rebuilding this one, or replacing the whole unit? I remember you mentioning in the past about getting just a seal kit.
I ask because every reman unit that you will buy from an autoparts store (that I have seen) will already have the backing plate on it. So there is no need to take off the retainer ring and the 'squared' nut. The reman units from Autozone & Advanced Auto have the backing plates. Heck, even getting one from the dealer ($650!) will have the backing plate. Here is a pick of the one that I got from AutoZone.
However, if for some odd reason that you are replacing it and the new unit didnot come with a backing plate, you can take it to a autoshop, from where they can use a air-punch and get it off for ya. I don't think it's really possible with just household based tools. I have an extra one that I can send you, but it would take a few days to get to you.
-graham
86 M1009
68
Mammoth Lakes Ca.
After all, I did not go with the seal kit. I got the rebuild from Kragen and I have to swap backing plates. The unit is notched for alignment so it wont turn inside the plate. I am gong to try hammer and punch again to get it off.
gasser
Ocean Springs, MS
Yeah, i just looked it up for a K30 - that is weird that it doesn't come with the backing plate. I understand the internals of the k30 would make it different for the Blazer (K5), but I don't see why they couldn't include the backing plate .... oh well.
-graham
