How hard to change broken studs??
Steamynachos
Calgary Alberta
One of the studs on my front driver side hub is striped and the nut just spins off by hand how hard is it to change them out and can you get the left hand threaded studs at Napa?? do you have to press out the stud like in a car?? Thanks guys
3,157
You just gotta pull the hub off and whack them out from the outside, and put them in from the inside. NAPA or any truck parts place will have the studs.
maddawg308
814
Appomattox, VA
RE: hard
Careful lining up the splines on the studs when you reinsert them. You have to make sure they are in the old splines, otherwise you will gouge new ones hammering them in, and weaken the studs to the point where they will spin in the socket. Then it will take a welder to make sure they stay in place, and that's not a good thing.
