Wolf.Dose
- 9
- 38
- Boehl-Iggelheim, Germany
If you have a look an the tachometer housing of your Deuce you will find that the setting is for 1500 rpm. This simply means, the average livetime is based on 1500 rpm. The usual lifetime of an engine of that design age is between 2000 and 5000 hours (depending on the maker). Or in other words, 2000 hours times 50 mph is 100000 miles, 5000 hours therefor some 250000 miles. This is under perfect engine conditions. You have to downrate this calculation by at least 25 % due to the tachometer setting. So a Deuce engine should live between 75000 and 187500 miles on perfect care, sometimes longer.
I know that here in Germany the trucks go for depot maintanance at latest after 50000 miles and then are set to a so called new status, which simply means, that these trucks are good for another 50000 miles in Army use.
Thats it.
And they are originally not made to run 400 or 500 miles a day. This normally does not happen in any Army.
Wolf
N.B.: The Jinmmy engine of WWII is designed for 15000 miles according to the m
l. After that a complete overhaul including new bearings is madantory. Even they kast longer in civil hands....
Thats it.
Wolf
![Banging Head aua aua](https://www.steelsoldiers.com/images/smilies/icon_smile_banghead_125.gif)
