- 26,246
- 1,176
- 113
- NY
YesDoes the in-tank pump run continuously?
It has not operated since I have had the truck, (that I know of). So, I am not able to do that test.houdel said:Do you get a good flow of fuel from the drain on the primary filter with the in tank pump running?
Time to pull the primary filter cannister off, clean out the crud, and install a new primary filter. If there is enough gunk in there that the drain does not flow fuel, chances are that the primary filter is also pretty well plugged up which will contribute to hard starting. Worse yet, if the primary filter is REALLY crapped up you could have fuel bypassing the primary filter, which NOT a good situation!oifvet said:It has not operated since I have had the truck, (that I know of). So, I am not able to do that test.houdel said:Do you get a good flow of fuel from the drain on the primary filter with the in tank pump running?
