How to add an EGT gauge with a PID
Floridianson
2,531
Interlachen Fl.
I would like to know the 'danger zone' temp as well!! Anybody have some info?
Seems like no matter what you run gas or diesel 1200* is a starting to worry point if it hangs there to long. Now as said if your are lugging it and RPM is not even close to red line and your hitting 1200* then that to can be a problem. Here you would down shift to bring up the rpm and see if the Temps dropped off. My EGT's with my Duramax when EFI live is turned up to the highest HP setting and I am passing or going to pedal to the metal for a short time. Have not melted them yet but as said I don't stay at those temps long.
20
Springfield AR
Solid State Relay the Abrins gauge triggers it with it's relay the water is injected through the intake elbow post turbo thought of adding a second nozzle pre turbo though the spray must be injected a certain way to prevent droplets.
coachgeo
3,546
North of Cincy OH
ohhh. SSR..... not ssd..... makes more since now. yup... on pre-turbo placement and jetting considerations.... droplets and turbo blades don't jive to well.
