How to clean out old pics
73m819
327
gainesville, ga.
You can use the picture icon above the text window in either quick reply or full reply. (Middle row of icons between the two world icons and the quote bubble icon) This will give you the option to insert an image embedded into your post. (Or delete the embed and it will remain in the post as a attachment in the attachment window) You do not clean out the uploaded images. There is not a limit to uploads here.
I will try again, ONLY up loading 10 at a time, we will see what happens, but this is how it is acting, thanks for your help
5,074
Nope! all those instructions and page posted showing a red x do not work. I (and I presume we all) Do NOT have a small red x at that top right. I (We) Do have a blue question mark ? where you had a red x is all. so NO option to delete.
Hover over the image in question in the top right to see the X. If it's an attachment that lives in a post elsewhere that cannot be deleted/edited, then you will (should) not be able to do anything with it. You must be in the specific post to have the images on the bottom segment of the attachment manager window to remove them. Also confirmed this works fine from a normal user account (not my account), and from chrome as well.
5,074
And just to qualify, can we remove/delete pictures from the upload picture stored folder..yey or ney? Thanks.
You cannot remove images from the top segment. Only from posts. Unless it's uploaded, then deleted immediately before the cron.
73m819
327
gainesville, ga.
But If I hunt down old post, I can delete them from the post, THEN delete them from the up loader ????
5,074
If the forum rules allow an edit. BUT it will remain in your uploader since the cron would have ran and made the association with the file/post.
To explain the cron thing simply. Imagine a robot that runs on the hour with the task of taking pictures and putting a copy in a filing cabinet. The robot only knows to take the image copy and put them away. So if you go out there to the filing cabinet and remove the picture, the robot doesn't care. Because it's task is only to put the pictures out there. But the "original" will still remain.
Again, there is no limit to uploads.
