godzilla
- 0
- 0
- Selinsgrove,Pa
I'm thinking about getting a m35 or a 5 ton from gl. I'm in pa, whats the most cost effective and legal way to get one home from gl. Thanks
INSURANCE!!! Make sure you add it to your policy before you drive it 5 feet!
Even if you dont register it or get a temp tag, you better have insurance.....
Are you old enough to drive?I'm thinking about getting a m35 or a 5 ton from gl. I'm in pa, whats the most cost effective and legal way to get one home from gl. Thanks
While keeping in mind that once you own a 26000 plus truck you can just take the driving test in it and get the B licenseA 5 Ton is very close to 26,000lbs. It is the magic number most states use to decide if you need a class B drivers license. Be sure you can legaly drive it before you buy it!!!
A 2.5 ton is no problem as long as you use the off road specs when you register it.
An M818 tractor W/OW weighs about 19500lbs. Later, get a nice van trailer then go for your Class A.A 5 Ton is very close to 26,000lbs. It is the magic number most states use to decide if you need a class B drivers license. Be sure you can legaly drive it before you buy it!!!
Any "big truck" experience?I'm thinking about getting a m35 or a 5 ton from gl. I'm in pa, whats the most cost effective and legal way to get one home from gl. Thanks
