"How to get a HET in life..." - M1070 Acquisition thread
fuzzytoaster
3,761
Fort Worth, Texas
Yesterday I helped a friend pull his auction win M819 tractor wrecker home. The HET handled it just fine. The 819 is cool! It'll be a neat restoration.
Thank you for saving that one. I was watching it close and had to resist saying anything on here before it closed. Do tell your friend to take more pictures and video, they are a neat truck!
Carlo
21
palazzago italia
I used a set of towing lights that I have. Since the cable for the lights has a military 24v 12 pin connector and the HET only has a commercial 12v 7 pin connector by the pintle hitch, I had to run the cable up to the military connector by the fifth wheel. They work very well.
I've seen these towing lights on stone web sites there in the USA. I did not know they had 24 volt. I will check into these.
Thanks Matt!
buggyman
-1
Ontario, OR
I’m just a country boy and was wondering about pulling animplement about 5 mph. I would really appreciate some information on thesetrucks. I need to know how fast these will go in low range for 1[SUP]st[/SUP] and2[SUP]nd[/SUP] gear? Thanks, Paul
Castle Bravo
Hundredaire Socialite
233
Arizona
2100 RPM in 1st gear is 9 mph
2100 RPM in 2nd gear is 14 mph
DrillerSurplus
Salt Lake City. UT
This made me curious about how the HET compares to something like a Kenworth T800 with a similar wheel base and to other mv.
The TM_9-2320-360-10 lists a 67.9' turning radius for HET without trailer, wheel base appears to be 215". The Kenworth book didn't list any tridems, but heavy tandems with 220" wheelbase had turning radius of 44'. I thought maybe the M920 would be better with the airlift axle, but it is actually worse, so the M1070 was a pretty big improvement.
The information below is from a 2011 SS thread posted by runk http://www.steelsoldiers.com/showthread.php?68712-M916-M920-wheelbase The information available on this site is amazing! I just added a couple of dimensions for the Kenworth & HET.
from TM 9-2320-273-10
Minimum turning diameters, curb to curb, are listed below:
M915 53.5 feet (16.31 m)
M916 80.0 feet (24.4 m)
M917 89.5 feet (27.3 m)
M918 80.0 feet (24.4 m)
M919 89.5 feet (27.3 m)
M920 89.5 feet (27.3 m)
M1070 67.9 feet
T800 44.0 feet
DIMENSIONS
Length (overall, less pintle hook and lifting shackle)
M915 268.50 in. (6.82 m)
M916 294.30 in. (7.48 m)
M917 350.60 in. (8.90 m)
M918 350.60 in. (8.90 m)
M919 374.40 in. (9.51 m)
M920 319.30 in. (8.11 m)
Width (overall)
ALL 96.75 in. (2.46 m)
Height
M915 134.63 in. (3.42 m) (over stack – empty)
M916 142.00 in. (3.61 m) (over stack – empty)
M917 141.00 in. (3.6 m) (overall)
M918 142.00 in. (3.61 m) (over stack – empty)
M919 142.00 in. (3.61 m) (over stack – empty)
M920 142.00 in. (3.61 m) (over stack – empty)
Height (reduced, no load)
M915 114.63 in. (2.91 m) (over horns –empty)
M916 128.00 in. (3.25 m) (over horns – empty)
M917 Not reducible
M918 128.00 in. (3.25 m) (over horns – empty)
M919 128.00 in. (3.25 m) (over horns – empty)
M920 128.00 in. (3.25 m) (over horns – empty)
Ground Clearance (under rear walking beam bracket) (empty)
M915 10.25 in. (26.03 cm)
M916 11.62 in. (29.51 cm)
M917 12.00 in. (30.48 cm)
M918 11.62 in. (29.51 cm)
M919 12.00 in. (30.48 cm)
M920 11.62 in. (29.51 cm)
Wheelbase
M915 168.25 in. (4.30 m)
M916 186.00 in. (4.72 m)
M917 211.00 in. (5.36 m)
M918 186.00 in. (4.72 m)
M919 211.00 in. (5.36 m)
M920 211.00 in. (5.36 m)
M1070 215 in.
T800 220 in.
NDT
7,535
Camp Wood/LC, TX
Thanks for posting the two side by side. I think this is the only photo of the two generations ever taken. Quick question, why does the SO have a huge piece of flex coming off the stack?
Castle Bravo
233
Arizona
I don't know, I've wondered about it every time I've seen the truck.
Bighurt
46
Minot, ND
Thanks Matt, does that truck just sit out on display or does the Sheriff ride it around? LOL
Doesn't look like it in the the picture but a M1070 will tow a M747 trailer with the landing gear kicked back. First question I asked Soni when he go his.
MO MV man
Imperial, MO
I'm guessing the flex tube is to keep exhaust soot from getting on the tank?
Castle Bravo
233
Arizona
It just sits there, rotting in the sun. A lot of the tires are very cracked.
Yeah, I think Soni said you have to remove the mudflaps on the 1070.
Bighurt
46
Minot, ND
Such a shame, rig like that should be preserved and make the rally circuit.
That's a correct statement, although if memory serves he made it seam the chore to fold the gear all the way back. The flap removal is almost SOP by comparison.
Castle Bravo
233
Arizona
I came across a deal on some JW Speaker 8700 headlights that I could not pass up. I had some Trucklite LED headlights ready to put into the HET, but was waiting because I hadn't had time yet to make the necessary bracket to kick the headlight guards out. The JW Speaker headlights do not need the bracket and I think they look cool, so I got some. When it gets dark, I'll drive around and see if they're aimed correctly.
