So I scored an Asco series 300 200A transfer switch on CL today for $300! These units normally run about $2000. I also picked up a 200A service disconnect breaker since the Asco is not Service Entrance rated.
Here are a couple of pics of the pair:
http://www.cstone.net/~dk/asco300-01.JPG
http://www.cstone.net/~dk/asco300-02.JPG
Some more pics of the Asco 300, which is virtually new looking!
http://www.cstone.net/~dk/asco300-03.JPG
Closeup of actual transfer switch. Note the neutral connection bar on the left and ground connections on the right.
http://www.cstone.net/~dk/asco300-04.JPG
And the controller box.
http://www.cstone.net/~dk/asco300-05.JPG
And with the cover off exposing the microprocessor. I plan to add the communications module, which will add an Ethernet port so that I can monitor/manage the switch from any computer with a web browser. It will allow me to monitor voltage and frequency of both the utility and generator sides.
http://www.cstone.net/~dk/asco300-06.JPG
Got the service disconnect and transfer switch mounted next to my 200A panels. Note how the power from my 400A meter base comes in from the outside via that conduit in the middle of the picture and feeds each 200A panel.
http://www.cstone.net/~dk/asco300-07.JPG
I have read the other threads here on how to ground everything to a single point and I *think* I got it right on the mock up wiring diagram below.
L1 - Red
L2 - Blue
Neutral - White
Ground - Green
http://www.cstone.net/~dk/asco300-08.JPG
I'll be removing the grounding straps that currently bonds neutral and ground inside each 200A panel.
Also, I'll be running individual 3/0 copper from the Load terminals on the Asco transfers switch to each 200A panel. I'll need to trim the wire a little on the transfer switch end as 2 3/0 wires won't fit in the lug terminal. I know that I should technically be using a 400A transfer switch, but when I add up all the loads in the house, it comes in under 200A. The reason I got 2 200A panels is just due to the number of individual circuits. Water heater and stove are both propane. Heat pump is 20 seer with scroll compressor (Trane 4 ton XL20i just installed last year).
Should I for some reason draw over 200A, the service entrance breaker should trip I would think.
So outside I will have a MEP-802A which will be the primary generator and it will be connected to the Asco transfer switch by default via a 100A manual transfer switch. From that manual transfer switch, I'll be able to switch the emergency power over to a MEP-003A for the times that I'll need more than 5Kw of power (like when the aux heating elements come on during the winter and the heat pump goes into defrost cycle).
More to come.
L1 - Red
L2 - Blue
Neutral - White
Ground - Green
More to come.
