How to jump this 10 kw genset at the starter
98G
Former SSG
4,424
I've got a 10kW DC APU generator with a HATZ 26hp engine.
I've jumped old chevys at the starter using a screwdriver, main positive post to secondary empty post.
The partition around the main positive post on this one seems designed specifically to prevent that. Maybe there's a good reason for that...
I've got a buyer if I can demonstrate it running. I don't want to damage it in the process. Maybe
98G
Former SSG
4,424
Resolved. It's now running.
Ray70
5,854
West greenwich/RI
Rather than jumping across the main battery post like that you should be able to use a small jumper wire and go from the battery post to the small trigger wire that appears to be below the shield next to the motor power wire ( the smaller black wire with the blue 1/4" Faston connector and the yellow stripe around the wire. If that is the starter solenoid power wire, just apply power there and save your Craftsman from getting the jaws pitted.
98G
Former SSG
4,424
Thanks. I guess the pic isn't clear. I went from the main positive on the top to the little skinny trigger post from where I had removed the trigger wire. Amperage was minimal. It fired right up.
Now my buyer has gone silent.
Ray70
5,854
West greenwich/RI
Ah, ok... I probably looked too quick and thought you were jumping right across both fat wires! Apparently you figured out he answer already!
If you want to get fancy you can make a couple leads with alligator clips and a momentary switch, if your buyer comes back to life!
They sell the same thing too, remote starter switch, like $14 at harbor freight.... guaranteed to work at least once!
