How to remove the instrument cluster?
Rutjes
272
Amersfoort, The Netherlands
As the title says, how do I remove the instrument cluster? It's in there pretty tight? I can wiggle it around, but I don't see a way to pull it out!
Zadvark
North Carolina
No magic advise but mine was wedged in pretty hard between the upper and lower edges of the sheet metal portion of the dash. Wiggling it out went a lot better than pushing it back in. Next time around I may take a hair off the opening in the dashboard.
Rutjes
272
I feel kinda stupid now, but it turned out to be pretty easy.
Slide it left a bit, then angle the top forward, remove the plug and pull it out.
It might indeed be easier by taking a hair (or two) off the opening.
Sent from my A0001 using Tapatalk
cucvrus
10,427
Jonestown Pennsylvania
Very carefully. They are as brittle as fresh crisp potato chips. Careful with the shift cable slide area and the left out ear. I have a fix if any of these are broken. Never break again. Good Luck. Now that you have it out. I hope it goes back in as easy.
Rutjes
272
I think you are right about the brittleness. Although I did not break anything, someone before me sure did, still use-able tho.
I thought about cleaning up the circuit a bit, but new ones aren't THAT expensive. In an old thread (2012) I saw someone mention LMC part 83-8036 (without gauges, 81 to 87). The example image seems match with what I have in front of me, but someone said "no, it has to be military", thread died after that. Does anyone know if it will fit, or if this guy's right?
For now, I'm going to clean the parts, man are they dirty. Gonna give the whitish plastic a rattle can make-over with high gloss white and repaint the steel black cover as well. Someone had cut the bezel apart for a radio, I won't use one (will use a bluetooth receiver hidden somewhere, connected to an amplifier) so I'll fill the gap up and give the whole thing a matte black finish. Gauges show some rust and peeling paint, will keep them for now, but definitely want them replaced sometime.
Oh and another thing, I've been thinking about making new covers for the idiot lights as the symbols/circles on mine are worn. Anyone interested in having some as well?
