I have a crack at the top of my overflow tank near where top fitting is located.
What type of glue/adhesive would you guys recommend for fixing it?
There are lots of choices out there, like Gorilla super glue gel, Loctite super glue plastics bonding system, Gorilla epoxy and J-B Weld plastic weld.
What would work best for the overflow tank?
Of the ones linked above, I think I like the Loctite the best with the primer and glue. Just apply the primer, let it dry, then add a few drops of the glue.
