AnonymousOne
- 16
- 18
- Boston MA
Hi,
As your aware, GL paints over the original truck markings on the bumper. Bumper numbers are useful to find out where the truck is from and important for some folks who want to truly keep the original nature of the truck.
Here is what my dad showed me to do get the number .. of course you will need to repaint the whole thing when done but you will have the original truck ID number and what group it belonged too.
1. Get a tooth brush, paper towels, small container and Acetone (chemical depends on what type of spray paint was put on your truck)
2. Put the acetone in the container.
3. Dunk the tooth brush in the container and find a GL Spray painted "test spot" to see if Acetone is the right chemical to use. Brush semi hard .. the GL Spray paint should come off. Vary chemical to one which dissolves the "Test Spot" leaving the truck paint. If the truck paint comes off too then STOP .. wrong chemical.
4. Use the paper towels to wipe the test spot dry. Do NOT rub hard with the paper towel. Wipe softly to dry and pick up any loose paint.
5. Once the chemical has been proven on a test spot .. then repeat on the real part of the bumper where the numbers should be.
6. You will need to start guestimating on the numbers and letters as they start to show up to clean around them with the tooth brush. Though you can brush semi hard with the tooth brush at some point you will brush the numbers and letters off too. Use caution.
7. If you start on the back bumper, if you screw up you can always do it on the front bumper. Also some numbers and letters may be in reverse colors so don't always look for black letters, look for tan letters too.
8. Good news, the worst thing that can happen is that you have to use a cheap can of black spray paint and re-do the GL paint on your bumpers.
Hope this helps someone.
PS - Even though I am 45, my dad is still my hero![A toast to MV's :beer: :beer:](https://www.steelsoldiers.com/images/smilies/beerchug.gif)
