Hub Removal Tool
SGT Estum
Twin Cities, MN
Does anyone have advice on where to get the tools required to tear down the front hubs on my M1009? I've seen several threads of guys getting their M1009s with bearings in need of attention so I really want to take mine out, inspect them, and repack them.
Per the manual, I need Nut wrench, J-34616 but I can't find it anywhere. Unfortunately I can't get past "Remove adjusting nut (4)" in paragraph 8-4 of the -20 TM.
Any guidance would be greatly appreciated.
CROM
Des Moines, IA
It's a pretty standard tool. If you ask your local auto parts store, they can look up the part number for you no problem. You'll need some leverage to get the nut off and a torque wrench to install in properly when you're done.
When I check mine, I lay everything out in the order it goes back in to make it simple. Also, while you're in that deep, you may want to check your spindle bearings, as well. The spindle needs some 'persuasion' to come off. I find that if I lay a piece of 2x4 on the the spindle and smack it with a hammer on one side, then the other I can work it off of the axle.
DavidJBlythe
Fort Meade, MD
It is a four tooth sprocket (usually 1/2" drive). Advance or Autozone should have it in stock as a "1/2-ton Axle Nut Removal Tool (or sprocket)". Ditto on laying it out in order.
SGT Estum
Twin Cities, MN
Yeah, I thought it would be a pretty standard tool too. The guys at the local O'Reilly's have given me two incorrect tools thus far. Maybe the third time is the charm? Or maybe I should try NAPA/Autozone and see what they can do.
1,172
Surely the tool part number and brand names, have been posted on SS. Perhaps a few minutes of searching would help?
SGT Estum
Twin Cities, MN
SGT Estum
Twin Cities, MN
Please pardon my mechanical ignorance here... but are there any tricks to removing the seal that holds in the inner wheel bearing? According to the TM, I need to remove the inner seal (18) but I'm not sure exactly how to do that.
In my picture I assume that #2 is the seal but #1 needs to come out first? Any advice?
DavidJBlythe
Fort Meade, MD
Some people will put the hub assembly back on, screw the same 4-slotted axle nut on the threads, then pull the whole assembly forward really fast. This will catch the inner bearings and stop their movement while allowing the hub assy to come on forward. The bearing and seal will be left on the axle shaft.
top_prop
Suffolk, VA
I've read the thread Doghead posted above and a few others... I'm confused about one thing... with the M1009's: what year requires the 6 lug tool instead of the 4 lug tool?
Wolf.Dose
9
Boehl-Iggelheim, Germany
The hub nut tool is a standard chevy part, as mentioned above, for the 1/2 ton rating. Must consider you MY, there was a change in 1986. But the part shops do know that. Bought mine years ago just with mentioning Blazer K5 MY 86, August and got the correct part.
Remove the inner seal: For you want to peplace it anyway, you may destroi is. Just use a crawbar or simmelar to remove the seal.
Wolf
CROM
Des Moines, IA
You will destroy the seal when you remove it just like Wolf said. Just buy a new one and be carefull when you install. Don't be shy on getting it out, hammer and chisel/big flat head screwdriver work great.
Side note: There is a spring in that seal that is notorious for finding its way out of the seal and into your bearings...be carefull on the install.
1,172
I use a brass punch and drive the bearing out, forcing the seal out also. Replace the seal and clean/inspect/repack the bearing. The new seal gets "pressed" in(hammer and a block of wood will work fine), or a large socket. Only press it in by its outer edge.
