Hub Removal Tool
DokWatson
Wasilla, Alaska
Please pardon my mechanical ignorance here... but are there any tricks to removing the seal that holds in the inner wheel bearing? According to the TM, I need to remove the inner seal (18) but I'm not sure exactly how to do that.
In my picture I assume that #2 is the seal but #1 needs to come out first? Any advice?
I put the hub on the floor and use a long socket extension to remove everything. Goes back in the same way it comes out, then I tighten down the spindle nut as far as it will go to suck everything back into place. Back off the spindle nut, then torque to proper specs.
Wolf.Dose
9
Boehl-Iggelheim, Germany
O.K., I was wrong with the modell year of the change of the hub nut. Anyway I think it was a usefull advice.
Normally seals are set with a special tool to install then without demage. However, who has that on hand. So a peace of wood or something simelar of course will do it.
Normally the job is done with the propper tool and a press.
Wolf
SGT Estum
Twin Cities, MN
I was thinking a slide hammer might be handy for getting that inner seal off... any reason not to use that? It will make a nice addition to my tool collection 8)
Good advice on that spring - I definitely don't want that getting into my bearings!
1,817
OK, at the risk of getting chewed, I'll share my method of getting the seal out. Remove hub, outer wheel bearning nut, lock ring and inner wheel bearing nut. Now remove outer wheel bearing and re-install the outer, repear, outer wheel bearing nut onto the spindle. Screw it on until threads are exposed. Now grab the rotor and slide it off keeping downward pressure on it. Works quickly every time. As far as the 4 pt and 6 pt nuts, that confuses me. Every half/3/4 ton I've ever worked on had the 4 pt nuts and the Dana 60 and 14 Bolts had 6 pts. Mind you I've not done much on th 1009s except the 84 I had years ago. My 91 burb has the 4 pt nuts.
2deuce
145
portland, oregon
I'm replacing the rotor on my daughters M1009 and saw this recent post. I too have only seen the 4 point nuts until now. This M1009 has a 6 point that is in the threads of the nut (inside) and it's smooth and round on the outside without the 4 slots that I have seen before. Does anybody know the tool number? My napa doesn't have it.
Thanks,
Greg
OddballJ
Raleigh NC
Thanks,
Greg
When I tore mine down I actually had both a 4 and a 6 slot on the same hub. I went to the local Advanced auto parts store and rented a 5 piece hub removal socket set. I believe the one that ended up working mushroomed out and actually only had 4 teeth, but it worked. Good luck :)
