Huh, This Will Get Me Flamed...
spicergear
26
Millerstown, PA
:idea: Okay fellas, we see M1075's rig with the big 46" Mich... XML's on it, I'm soon to have a set of 46" XL's on mine and had a thought so I went to Randy's Ring and Pinion and played on the RPM/MPH calculator there.
(http://www.ring-pinion.com/content/calculators/RPM.asp :deal: ...if you're interested)
Anyway...
6.72's, 39" tires (NDT's), .85:1 overdrive (3053) = 2,707rpm @ 55mph.
6.72's, 46" tires (XML/XL), .85:1 overdrive (....) = 2,295rpm @ 55mph. *not a bad drop.
Now...we've REALLY stretched out our rolling circumference and lost a bit of power. IF, for arguement's sake, we hauled a lot and needed more power and less room between gears...a fella, a fella not hung up on going much over 55mph, could slap in a 3052 non overdrive from an old Gold Comet gas REO and get this:
6.72's, 46" tires (XML/XL), 1:1 direct = 2,700rpm @ 55mph.
--So possibly would gain, or at least not lose, oomph with a shorter step between gears and still be at a traditional M35 highway speed. [thumbzup]
hot rod deuce
Kasota, Mn
hmmm im goona go plug in my 53's at 3000 with the cummins...maybe a 13 speed direct wouldnt kill me after all but 55 is a little slow....for me anyway and who wants to run that many r's what we all meed is an 18 speed double over that is small and light weight...not to mention almost free
Desert Rat
HRD,
We also need to hit the lottery every week too............................ It is a nice thought though. Personally I really liked my old 13 over with the 4&1/4 3406 purely mechanical Cat.!
