erasedhammer
- 56
- 28
- Maryland
I was wondering what the difference was, electrical-wise, between the two. I've seen the two on epay and they appear to be mounted in a similar case, but I would like to know if the computers inside are identical.
I am using the hummer h1 oil pump drive rpm sensor to feed my 4l80 with the engine speed. As far as I can tell it came right off a 93 hummer and it was hooked up to the tcm in that H1. So it obviously feeds the hummer's tcm the correct rpm and signal, wondering if it will be correct for the military tcm.
