Hummv rims om M1028
1,192
Section II. TM 9-2320-280-24P-1 Figure 167. Wheel and Runflat Assembly.
Samyguy
Lincoln Ne.
thank you' for the link, pretty much straight forward.
So in my case I'll keep my air psi down and won't add 8000# of
steel plate to my CUCV like they had been doing on HUMMERs
allrevup
Delaware
Thanks for ALL the links doghead! Also the #9 post on the pirate4x4 tred link about the way it would blow OUT or IN is a very good observation.
I feel that you could used radials on 8 bolts wheels as long as you do not exced the wheels 30psi. max air pressure and that at that max tire air pressure you have enought tire for the vehicle/application that they are under.
What Is structuraly different to makes one 12 bolts wheel/tire combination have a higher Weight Rating then the other= alingment hole instead of a washer and a different "O" ring= 3,900lbs. How?
1,192
Look at the picture from the Tpub. You can see the design difference there.
I think there is a thickness difference.
On my truck, I regularly run my tires at 45-50 psi. I trailer and haul loads in the bed. I played with tire pressures and found 45 to be about the best for me(temp, wear, contact, sidewall flex).
I would hate to have someone read the sidewall max pressure and think they were safe to inflate to that , if my tires were on the 8 bolt rims.
1,192
That I don't know.
