HUMVEE 29Z wire info needed
murilod
Seguin, TX
Hi,
Im working on a M1114 and I can not find where to connect the wire 29Z. This wire is in the same area of the Transmission (TCM) manual reset ( behind the battery box) The wire was cut off So I dont know if was a male or female connector.
Any help will be well appreciated!
Best Regards,
badgerd
Electronic Jedi
42
Chesapeake VA
There are 2 “29” wires in that area, 29D from the run switch to the circuit breaker and 29T from the circuit breaker to the 12V relay for the TCM. I can check to see what the 29T is later for M/F if that’s the one you need. I don’t have the original breaker installed to check the other.
Sent from my iPad using Tapatalk
murilod
Seguin, TX
Thank you for the help !!!
The cable still have the id tag on it The tag number looks like a 29Z Also this Humvee have 3 relays side by side I think one is for the AC I dot know what is the 3rd is for it ( just throwing some extra info)
badgerd
Electronic Jedi
42
Chesapeake VA
Circuit numbers are the "same" throughout a vehicle as long as it hasn't been "fooled" with. The 29 circuit should be 24V from the start/run switch since that's what it is going to the trans relay. It's safe to assume that your 29Z is switched power for one of the other two relays, but I wouldn't be able to say whether it's a male or female connector required.
murilod
Seguin, TX
Thanks !!! I think Im going to leave this wire disconnected for now And see what does not turn on after I start the truck.
