Hello fine individuals, I started hearing some noises today that nobody likes to just start hearing out of the blue.
Basically, I've had this M1043A2 6.5L for almost a month, been getting it fixed up while waiting for the sf97 to come in. Today, I installed a new oil pressure and voltage gauge, as the previous ones had water intrusion. I take it out for a drive, and I'm about 20 minutes in with the engine at full operating temperature. As I'm driving at around 35-40MPH, I start hearing a very audible clacking/smacking sound, very different than anything I've heard from this machine yet.
I pull over and shut it off and then proceed to look around the engine bay for anything loose, the only thing I found was that the crankshaft pulley has a little bit of play in the rubber. I start it again and rev it slowly a few times. The clacking follows the engine RPM, and is 100% not part of the normal diesel clacking sounds you typically encounter.
So far.. I've read that it can be a few things:
1: Bad injector
2: Cracked piston / head
3: Loose pulleys / bad bearings
4: Other fun things
Trying to narrow down what it is, I took a video and the sound is very evident around the 30-40 second mark:
If anyone's heard this before or has any ideas on what I can check, would be appreciated. One thing of note is that my bottom-most injector line on the injection pump is pretty rusted, so there may be a possibility of air getting in the line? But it doesn't seem to be leaking either. I'll probably start by pulling the injector lines one-by-one and seeing if the noise persists.
1: Bad injector
4: Other fun things
