Yea I've heard that bad ones can cause it to sound like a bunch of monkeys banging sticks around. A new set of 8 off fleabay looks to run about $270-$350. I just don't want to replace them all and then still end up hearing the noise
I guess that's what I signed up for
Engine cleaner? Maybe ATF ??My buddy on a gasoline engine in his 1999 Durango developed a bad tap. He was going to get a new engine. I changed his oil with engine cleaner and ran it for 5 minutes. I then replaced with cheap oil and ran for 10 minutes. I then replaced with good quality oil. Tap was gone. Engine lasted another 120,000 miles.
Moral of the story, don’t stress out.
They make an engine oil cleaner. I forget the name. ATF and Marvel Mystery Oil are all things people use also. This engine oil cleaner has helped me unstick valves before. I just forget the name.Engine cleaner? Maybe ATF ??
Sound great!Alright so… update on the situation:
I changed the oil and filter yesterday, per the immediate recommendation of some of you. drove it around several times, getting it up to full temp each time. Didn’t hear the knocking the whole day. Now I’m gonna sit here and hope I don’t hear it again.
I shall tuck this knowledge away for future reference, thank you all for your inputs. I’ll monitor this over the next week and hopefully the stick banging gremlins stay at bay.
Most of the TIme i use one of this products here:Engine cleaner? Maybe ATF ??
www.liqui-moly-shop.ch
Just put in a real big kascar order, going to be funCongrats on the new truck. I am also new to the HMMWV world but have learned a lot in a short amount of time. Like others have said I would change out all the fluids, fill it with fresh fuel add a bottle of Diesel Kleen with the new fuel.
Spindle nut and tab service is a must-do. You do NOT want one of your wheels falling off while driving. Also, make sure you check and torque all half shaft bolts because they can also cause a wheel to fall off. Check tire pressure, lug nuts, etc.
Grounding harness so you can make sure you do not chase your tail with electrical issues that could be cleared up with a harness.
Fix any bad bulbs and electrical issues.
Check and replace any bad belts, hoses, etc
A thorough check of all brake components, steering components, pitman and idler arms, etc. Check for any leaks (transmission, oil, CV boots, coolant, etc)
Go over every inch of the truck looking for anything. The best example I can give you is the positive and negative bolts on my starter were missing with just the wires just pushed onto the studs. I am lucky I didn't burn the truck up with that one.24 Volts is some serious stuff.
I probably missed a few things but you get the idea.
Then once you think everything mechanical is up to par then you can start on the upgrades, cosmetic fixes, etc.
I can say that some of this stuff is fun to me and enjoy wrenching and seeing the truck come together. However, it can get pricey depending on what goes wrong. I am fortunate and have a guy local to me that works on military vehicles for a living. We call him the "Humvee Whisperer" so if I get stuck with an issue I can't resolve or just don't feel like messing with he can handle it and even makes house calls.
I hope you have resolved your issue and dodged an expensive bullet. Again, congrats on the truck and hope you enjoy it.
cold advance is automatic, no need to touch the pedal to se anything. The CA expires at 120, it’s controlled by the CA thermostatic switch on the right rear head. also turn up your idle to about 675-700, they idle better.Yea I had that line cracked specifically since I suspected an issue with that injector, so the rough idle was expected. It still clacks with that line connected, and the cold advance was part of my theory, but I'm missing a few pieces of information to make sense of it.
I thought the cold advance needed the throttle to be nudged forward after setting the switch to "run". Is the normal temp for the advance solenoid to come off around 160-180? That's when the sound goes away. In terms of pump timing, mine is advanced towards the driver side, but a very small amount and less than the previous pump at least. If it's not worth playing with and nothing is getting harmed, I'm completely fine with it hehe
Thanks for the input!
So theoretically speaking, if I disconnect the cold advance from the pump itself, should it sound different?cold advance is automatic, no need to touch the pedal to se anything. The CA expires at 120, it’s controlled by the CA thermostatic switch on the right rear head. also turn up your idle to about 675-700, they idle better.
