- 7,547
- 10,592
- 113
- Papalote, TX
Everything else aside, if that bendix cannot even be pushed back at this point you have a mechanical issue with the starter.
It's the switch!!!!!!
I can say with 95-99% confidence now that the switches I have been receiving are all garbage. I yanked the starter, did a battery of tests on it, and then did some testing with different switches installed onto the truck.
So here's what I did.
Test 1 (Starter Solenoid Bendix/Contactor Actuation Voltage):
I needed to confirm my initial suspicions on solenoid engagement voltage, and see how the solenoid acts when undervolted. My theory was that it was getting enough voltage to kick out the bendix to tickle the flexplate, but not enough voltage to close the contactor and drive the armature.
I hooked up a multimeter in continuity mode to the contactor leads on the starter. I set up a bench power supply at 16V and closed the solenoid. As expected, fork moves and bendix tries to engage (albeit seized in this case), but no continuity on the contactor leads. It was not until 22V that both the bendix and the contactor are in their proper positions. In any case, the solenoid is acting exactly how I figured and expected it to (it's not just either on or off, but it can be somewhere in between when undervolted)
Video:
For the following tests, the start switches were installed in the truck, multimeter set to DC Volts, negative lead on the starter ground cable, positive lead on the solenoid positive wire
Test 2 (New Mac Motors Switch):
Voltages based on switch position:
Off: ~13V
Run: ~16V
Start: ~25V
Video:
Test 3 (Original HMMWV Switch Stolen from Friend's Truck):
Off: ~0V
Run: ~0V
Start: ~25V
Video:
This tells me with almost absolute confidence that swapping for the new switch caused the starter to get stuck engaged in the flexplate, but not engaged enough to drive itself off voltage from the contactor closing.
Sad to see a starter fall victim to a faulty switch, but at least now I know this much more about the start system on these![]()
Indeed, going to run the same tests I just did for any “new” switches that I get. Not sure about the starter procurement situation though, will make some calls tomorrow.Sounds like all you need is a GOOD switch and another starter![]()
If you got it from Mac, I'd definitely contact them about it. Maybe you just got unlucky and it really was a single bad switch. But if Mac Motor's inventory is full of bad switches, that is a much bigger problem (for them).Basically, the new switch I installed was still sending 13-16 volts to the solenoid positive wire even when in the off and run positions. The one I stole off my friend’s truck was sending 0 volts in the off and run position, as it should be like you stated.
So essentially with the new switch from Mac Motors, the truck would start fine, starter motor would disengage, but the bendix would remain partially engaged into the flexplate gear due to the 16V in the run position, thus the starter was being driven by the engine and bendix seized itself onto the shaft.
I’d try the remote start button too to eliminate variables but both of my starters are inoperable at the moment heh
I just checked. I ordered my start switch from Mac Motors on 1/5/22.. Installed it on 4/22/22. So far no issues.
HUM 11614131
5930-00-134-5036
Not to say all the switches that are shinny are bad... But if one has seen some of the plating of imported parts, mainly electrical and gauges, One gets a feel for the questionable products. I too have been there 22 years ago with a speedometer. Got the call that it came in and picked it right up. 50 bucks later and an hour, it was installed. I and the M37 were happy for about 40 miles. How could this be. Shinny new and now busted. Investigation revealed, unusual bright finish of hardware & brackets, no manufactures name / identification, plastic not as durable. Needless to say... All parts are not created equal.Hopefully it’s just a single one and not their entire inventory, will talk to em tomorrow.
In other news, spent a few hours and cleaned/wire wheeled/greased a bunch of grounds on the truck, along with installing the supplemental ground harness.
... and while engaged, how deep does this one go into the flexplate?No bendix engagement when there isn’t supposed to be.
About 2/3 is actually normal it appears looking at a couple starters that I have, the bendix teeth are wider than the flex plate teeth... and while engaged, how deep does this one go into the flexplate?
I wouldn't be so happy with a contact pattern of only 1/2 of the width on the ring gear teeth - even if it starts (and sounds) perfectly normal, every time.
