Humvee steering wheel stuck
erasedhammer
61
Maryland
i was going to replace my steering wheel and took off the horn and the nut while pulling upward I hit the center with a hammer. Didn't budge. I stuck wd40 down the threads of the center and waited a little, tried the same thing again. Didn't budge. By this point I'm frustrated so I try sawing the **** thing off. It's in pieces but the center still won't come off. I have NO idea what the military did to fuse the wheel to the steering column.
orgnal
Denver, CO
There is a tool for it. Search the internet for steering wheel removal tool. Autozone and such will loan it to you. The right tools make some of these jobs a lot easier.
McReddy
Stein12501
Tebbetts, MO.
Hate to say it but I don't think any of the steering wheel pullers will work at least they didn't for me. I made one from the threaded puller bolt, a piece of flat steel and 2 - 1/4" x 4" NF bolts. There are 2 threaded holes on the wheel. Soaked the steering shaft with PB and it came right off. I tried a 3 jaw puller on the steering wheel with no luck. Good Luck!!
orgnal
Denver, CO
I used one and I was done in 15 minutes.
McReddy
erasedhammer
61
Maryland
Do you know of anywhere I can get a replacement for the shaft that connects direct to the steering wheel. When I took the nut off, it practically came off without my help, and the treads were stripped. It looks like I'll need a replacement but all I can find is full steering column replacements
86humv
542
Texas
I have good columns available with or without a wheel.
i made my own puller....auto store units are to wide.
papakb
1,196
San Jose, Ca
Soak the shaft with KROIL. It's the best stuff I've ever found for rusted, nasty hardware and when you put the center bolt of the puller into the steering shaft be careful not to flare the shaft end of the shaft or your only option will be to replace the whole steering column. Luckily in the HMMWV that's a piece of cake to do because of the way AMG mounted it and they're pretty inexpensive when it comes to HMMWV parts. They have a habit of pulling out when people use them to help getting in and out of the vehicle. It's only held in with a bolt through a sheet metal bracket and that tears away pretty easily. There's a modification work order (MWO) that adds a supplemental bracket to the steering shaft but you don't see that many of them in the field.
