erasedhammer
- 58
- 28
- Maryland
I was wondering what/where to get the material that is used on the interior of the up armored doors. I'm looking to insulate my x-doors and already have a base layer down. I believe the material is almost the same as the roof liner material in a slantback.
The material itself I would guesstimate is about 1 inch thick and is made of a fairly robust foam with a slightly more rigid textured surface. Everything I find on epay that is a civi counterpart is not the correct thickness or is the correct final surface texture.
If you go on epay and search: "Insulation-AcousticaL-Panel-door-front-RH-HMMWV" it comes up with the material I would like, but not in a large sheet.
![hmmwv-m1151-frag-1-armored-door-set-new-crate-m1165-m998-military-humvee_172185311521.jpg hmmwv-m1151-frag-1-armored-door-set-new-crate-m1165-m998-military-humvee_172185311521.jpg](https://www.steelsoldiers.com/data/attachments/449/449711-676137942b3873bd536e250ce9210341.jpg)
![s-l1600.jpg s-l1600.jpg](https://www.steelsoldiers.com/data/attachments/449/449712-0c302362e5162d001b8716fd592c5c82.jpg)
