Humvee viscus fan conversion
Hummermark
31
London uk
What company was selling the fan and viscus unit as a conversion For the humvee instead of the stock hyd
set up
has anyone converted if so are you happy with it?
87m998
10
Idaho
I got my parts from Hummer parts guy. pn's 6013102 clutch and 6017546 fan. Its not a conversion kit, its what I figured out would work and it does. I did this when I got rid of the v belt set up and went serpentine. The noise is less and it keeps the temp down.
MattNC
271
Raleigh, NC
An ignorant question but how does it work compared to the stock M998 controller that just engages the fan on and off at a single temperature setpoint?
87m998
10
Idaho
Here's a description
A fan clutch is a thermostatic engine cooling fan that can freewheel at low temperatures when cooling is not needed, allowing the engine to warm up faster, relieving unnecessary load on the engine. As temperatures increase, the clutch engages so that the fan is driven by engine power and moves air to cool the engine.
MattNC
271
Raleigh, NC
Thanks. My question was how does the viscous clutch differ from the hydraulic one that comes stock in a M998? Does it no longer need the power steering pump and Cadillac valve? Does it engage progressively?
mgFray
992
Southern Minnesota
Correct, the viscous clutch works based on temp of the clutch unit itself. When it gets hot, it activates, when it cools down it free wheels. So no hydraulic pump/fluid/valve involved. This is the same approach used on a LOT of 1980's/1990's cars (before electronic fans).
MarkM
CODE BROWN...It's all going to sh~t !
1,149
2,099
WOBURN. MA.
How much air does the fan move? As I recall the stock fan moves over 2000 CFM.
Mark
mgFray
992
Southern Minnesota
I would assume it's a similar amount. Like the hydraulic clutch it just bind the fan 1:1 with the engine. So if the engine is spinning 2000 rpms, the fan is going 2000 RPMs. If the blade (or number of blades) is different that would affect overall airflow, but I would have to assume the Hummer H1 has a similar CFM for the cooling system.
Pegleg
Tulsa ok
Did that set up bolt right to the water pump pulley?
Hummermark
31
London uk
hi, I did eventually find the person advertising the viscous conversions (Mike Murdoch) for the Humvee. I purchased one - I don’t know if I had a bad viscous unit from him or not but mine stays on all of the time and does not cycle. It is as noisy as the fixed fan that I removed (Saudi/NY Humvees), so there is no advantage in having a viscous. As someone previously said, anyone other vehicle I have had or worked on including tractor trucks, when fitted with a viscous they come in and out with the temperature.
Has anyone else purchased a viscous fan for a Humvee from Mike Murdoch? If so, what is your experience with the fan, does it cut in and out or is it permanently on?
Pegleg
Tulsa ok
The clutch bolts to the water pump and the fan to the clutch as normal. The clutch operates as normal. If you look up the pn's I listed you can see.
Thank you it looked like it would but I thought I would ask to make sure
Do know the diameter of the fan the that I have found info say that the fan is 23 in diameter and my old fan is only 19.5 in diameter so do you have pic of it installed my Humvee is M1079A2 thank you
Pegleg
Tulsa ok
87m998
10
Idaho
My V belt fan is 19.5 and the serptine belt fan I have sitting around is 19.5. I didn't open up my engine to check, but it fits the fan shroud just fine. Don't make this harder than it needs to be. Call the vendors and ask? I listed the part #'s and a vendor.
87m998
10
Idaho
I got a measurement of @ 18.5" on the installed fan blade and @3/4" clearance on the fan shroud. The parts I used are AM general plarts and work just fine on my serptine belt set up.
GTUnit
155
CA
The fan part number listed " 6017546" is incorrect. This part number is for the 23" fan for the geared fan drive trucks. Serial #300000 and up
87m998
10
Idaho
LOL, what you say is incorrect is what I installed and it all worked just fine. You do know that you would never find in the parts cat, the parts to do this mod by serial # as it doesn't exist.
GTUnit
155
CA
You didnt just install the 23" fan in a 19.5 inch fan shroud because it won't fit. If you CUT THE FAN then maybe you should have written that in English that people can understand.
