HamAndEggs
- 51
- 18
- Houston, TX
Under 3000, seems very good condition but no paperwork available that I know of
Light towers around here usually have 15K+ hours
I think that lack of oil might behind Generac's call for once daily checks on oil levels on their air cooled units.I guess I'll share some generator Beryl pics, just to pay it forward. I know we all love seeing hurricane power outage pics (Or, am I just weird?)
6 days and 6 hours on generator power until utility came back. Generator has a Mitsubishi 4G64 2.4L I4 engine, ran great
Started with 24 hours on the oil and stopped when I hit 162 hours and did an oil change, that was a Saturday morning. I turned off the generator and switched to my cheap Champion Inverter unit via interlock while I changed it. Book calls for 125 hour oil change so I was a bit over, however later on an oil report showed the oil still had plenty of life left in it
Oil started on full and was just over 3/4 on the dipstick at time of changing, but I suspect a fair amount may have been in the unit and not dripped down into the pan, as I was rushing to get it done. I decided to stop and change as the CenterPoint Energy outage map updated to say we may have another 2 weeks of no utility
Fired it back up, and 24 hours later the power came back on...
This unit holds about 5 and a half quarts. My neighbors air cooled 24kw Generac holds just 2 quarts! After the same run time, his oil level was not measurable on the dip stick after starting full
Yeah, I would check the oil the very least every few days at minimum if I had an aircooled (Spoiler, I wouldn't own an air cooled)I think that lack of oil might behind Generac's call for once daily checks on oil levels on their air cooled units.
All the best,
2Pbfeet
I'd be happy to, but I didn't think that I had the privilege to do so. Where would be the best location as I don't know of a Marathon light tower military version. (My ignorance, I am sure.)@HamAndEggs FWIW: there are troubleshooting steps from Marathon below, along with the power generation circuits (brushless) at the end of this Marathon manual.
I think that the general issue with capacitor regulated generators is that the output is not super stable, but it depends on what you want the power for, e.g. running lights or heaters that are pretty indifferent to power quality vs say electronics.
All the best,
2Pbfeet
Its great you posted this document. Its helpful to the max. For this thread. But for all intents and purposes, its wasted, for the other hundreds of people who might need it. Its kinda buried. Please, when ever you post something in a thread, also post it in the TM forum. That way, its easy to find, and available to everyone.
Thanks, and posted in TM Uploads.Just start a thread in "TM UPLoad" Forum. A moderator will look at it to make sure its not a document that is not allowed to be posted and then he will put the thread where it belongs.
Not your ignorance, our not telling folks often enough to please do it. There are about a billion threads in the forum and I look through some of them to "Mine" for such gems. And this is one of the gems that is real good info. Even if its not military equipment, its info that can be used on military equipment. Thanks!
