Hutchenson rubber runflat/beadlock Questions
BKinzey
Hollywood, CA
All I've seen are pictures :roll:
First are they for 12 bolt rims only or can they be used in 8 bolt as well? Somebody is claiming they can't.
Can you use the beadlock insert without the runflat?
Angus1
Freeland,Pa
RE: Hutchenson Beadlock Questions
Ive seen guys in the wheeling world cut the run flat part off and just use the rest for a lock ring.
BKinzey
Hollywood, CA
It's the rubber type I'm asking about. I know it can be done with the magnesium type. I've edited the subject so that's a little clearer.
Thanks!
jeli
Stillwater, MN
Try looking at their web site. It shouldn't matter what rim style you have. They make different styles but they work the same. I know on larger tires they have a counter mine style that will help divert a land mine blast away from the truck. Not an issue hear but another random tid bit of info.
http://www.hutchinsoninc.com/
