Hutchinson Run Flat Lubricant
Dave2018
70
Texas
Looking fir a fair place to by a case of lubricant. Saw it around 20 bucks couole years ago. Covid price like 50.00 a tube. May have to improvise.
Thanks for all replys.
simp5782
Feo, Fuerte y Formal
9,367
Mason, TN
Murphys tire soap globs
In the event you are running on the run flats you won't be doing it at speed for long. It was in there for combat operations to keep the friction down when it is being used at speed
Coug
4,323
Olympia/WA
I'll agree with not really needing it for civilian use.
With the rubflat lubricant you can run 30 miles at 30 miles per hour.
In the civilian world, you just need to get to the nearest safe spot to either change the tire, or to get recovered.
Mogman
9,532
Papalote, TX
You should never put a petroleum product in a tire, tires are made using natural and synthetic rubber, natural rubber does not play well with petroleum products, while it is true that the inner sealing layer is butyl rubber it is just not a good idea.
The heavier duty the tire the higher percentage of natural rubber is used.
Retiredwarhorses
4,171
Brentwood, Calif
Do you know why the grease is used?
Do you know where the grease is applied?
Someone better tell the soldiers to stop using grease, RTV and god knows what else, I do a set of RF’s every week unfortunately and it’s always fun to see what was done by the previous installer.
Mogman
9,532
Papalote, TX
I would assume to lubricate the tire/runflat contact area during a flat, I have been told the RF "grease" is water soluble and would again assume it was designed to be compatible with the tire materials, what happens in the "field" is anybody's guess.
None of that changes the fact that putting "axle grease" in a tire is a bad idea. just like using a solvent like ether to "inflate" a tire is a bad idea, much of the solvent is not burned and remains in the tire to attack the rubber over time.
If you go to a real tire shop you will not find them running axle grease around the bead of a tire, they will be using Murphy's tire soap which is derived from vegetable oil, been there done that!!
Superthermal
830
Utah, Murray, United States
I have a set of MRAP tires with solid rubber run flats. I am moving the tires and run flats over to some HEMTT rims and when I went to clean out the tire of any water or debri that may have made its way in i found the tire coatedwith a tar gooy substance that I am guessing is this RF "grease". The question I have is I had been expecting to run 16oz of 50/50 antifreeze to keep 55mph wheel hop to a minimum. With this RF "grease" is this going to cause any issues if I do that? Any other suggestions?
87cr250r
1,988
Rodeo, Ca
I don't know anything about run flat tires but do know a lot about grease and rubber. Lots of tire and tire products need a lubricant for mounting. Some lubricants are grease like and water based. If you've ever built a 5-piece rim these will use a lot of said product. However, if you need a grease that will lubricate rubber over the long term without causing deterioration of the rubber you're going to need a silicone based grease. Dow Corning Molykote 111 is the industry standard for rubber and o-ring lube. It ain't cheap.
Coug
4,323
Olympia/WA
First thought is put some water inside and see if it's water soluble and easy to remove.
Second thought would be clean/scrape out as much as you can, then don't worry about it.
As long as it isn't impeding the antifreeze from being able to move around the tire, then it shouldn't be an issue. Worst I can see happening is it somehow not being compatible with the antifreeze and causing it to gel up somehow, but that seems pretty far fetched. I find it more likely that as time passes some of it might come loose and move around with the antifreeze.
You might also want to do more than 16 ounces of antifreeze, but it's easy enough to add some later through the valve stem if you need to. Antifreeze is cheap.
Superthermal
830
The material is water soluble and seems to "dissolve" easily when smeared with water. Even with no soap I could wash it off my hands with some effort.
When I have the next tire apart I will take a little and put it in a glass jar and do an antifreeze test to see if there is anything I should be worried about.
On the volume of 16oz of antifreeze 50/50 mix, that volume was suggested in a thread quote by SIMP.
country
392
Feasterville, Pennsylvania
Home > Parts > Run flat lubricant - Tire
SP-2902 | Run flat lubricant - Tire
$49.00
NSN #:
2640-01-419-6200
Part #:
12460308, D528235-H1
Run flat lubricant
Fits: Tires and wheels
Parts we offer for sale can be exported. Where necessary, required export approvals and licenses, U.S. Customs clearances and international / overseas shipping services are available.
BLK HMMWV
491
Pasadena California
I believe in the first Gen 2-piece Magnesium run flats the grease was in little packets that were taped / affixed to the run flat.
I'm guessing the initial concept was the that when the tire actually went flat it would pop the packet open and then coat the inside of the tire.
I'm also guessing that it was quite the sight to see a magnesium run flat / grease fueled tire fire. Even more exciting if they tried extinguishing with water.
Hobie_rat
North Carolina
Would be a hell of an entrance if you came in wheels on fire 🔥 lol
Hobie_rat
North Carolina
$49.00
NSN #:
2640-01-419-6200
Part #:
Run flat lubricant
How much is applied, 1 tube per tire?
