- 136
- 8
- 18
- Paulina La.
The metric double ended studs finally showed up so I put it all together today. I modified my pulley just like Ken did. I also pulled my hood and cooler stack. Not a bad job at all. The only issue I am going to address is the fan size. The 20 inch is tight, real tight. If you got this thing twisted up it might rub. I just ordered the 19 inch version. Easy swap when it comes in. Just took it for a 15 minute cruise with the hood off. Seems
like there is less noise? Very satisfied so far. I'll post up again when I can take a longer drive in it once I get help with the hood.
