Crapgame
- 329
- 63
- Navarre, FL
I just figured out why I FVBARed the hydraulic lines to the Control Manifold when I changed it out: The 24&P Manual is showing two different lines going to the same socket on the backside.
Figure 256 shows the Spare Tire lower hydr line going to Pilot and Suspension Compress
Figure 252 shows the lines from the manual pump going to Pilot and Suspension Compress
Does somebody have the correct routing diagram for the Hydraulic Control Manifold? I've got Joe coming down soon to swap out his M998 for the M1081 and I'm literally inflicting pain on myself trying to fix the few gigs I have. I need to be able to raise the cab to check the Throttle Position Sensor.
