Hydra-matic rebuild kits
DUUANE
91
Vancouver BC
I found this site and sent him an email regarding our dual range hydra-matics. He replied quickly and said he could supply rebuild kits.
I thought it may be usefull to us as ive read that parts are drying up. When i get mine out i may go through it and pack it up..or pass it on to a member that needs one, i guess itll rest on the need.
Not sure what the admins want to do but heres the link.
http://www.charlietranny.com/
Im not affilliated with them..and as yet have not made a purchase.
Hope this helps someone.
Hummermark
31
London uk
Hi I had a us supplied hydromatic rebuild kit I got for a m24 Chaffee but a few gaskets did not fit same shape different hole spacing.
ended up getting several cutting molds made i.e. Valve cover,drive output housing
USMC 00-08
137
Skiatook, OK
Does he have all the parts to rebuild the reduction unit? Some of the other suppliers have a hard time coming up with those.
yodraino
-1
ellensburg
Hi I bought the parts for my transmission from a company called Fatsco they deal in antique transmission parts some of the gaskets weren't the greatest and I had to remake them. They also rent the tools to set the front and rear band. Hope this is helpful.
gentrysgarage
118
Lost Angels, CA
After staring at this transmission, I have been trying to find a schematic/cutaway of this transmission. All I have found is GM car trans, none with/of the reduction gear. Here is where I am going...
It is true these transmissions were strong, I had the remnants of a 1965 GTO that had a alky hilborn injected 410 (started as a 389) with a Hydromatic trans that was running high nines in the late sixties till a HARD launch ripped the upper control arm mount out! These trans are tough, so if you wanted to run a hoped up 302 or bigger engine could you flip the reduction gear and make it an overdrive? You would need more torque for takeoff. This is just benchracing as I have no clue as to whats inside the reduction gear housing.
