- 2,756
- 2,410
- 113
- Sunman Indiana
I have a bunch of used, 25GPM, 1500-3000PSI adjustable, power beyond, dual, as well as single spool valves, that I'd be willing to sell. These should be a good option for you to run a single spool for your dump, then power beyond to a dual spool for your winch at a lower pressure if necessary. These are prince RD5000 series, they make some cool, plug and play, cable operated kits for these valves as well.I plan to do this to mine i will be putting a dump hoist under the bed and a hydraulic winch front and rear on the frame also on the bed i plan to run 2 pulleys in the front with cables hooked together at the end to run under the bed to the winch hook so i can use the rear winch to pull stuff in the bed also the s280 im getting has tow hooks at the bottom on the front so when the bed is tilted up i plan for it to be winched in with the 2 cables and the 2 cables stay mounted to the bed and unhook the winch after tying the shelter in place so i can use it to pull stuff onto trailers or recover vehicle including myself
