Hydraulic oil compatable?
gimpyrobb
dumpsterlandingfromorbit!
27,785
748
Cincy Ohio
I ended up with 2-55gal barrels of Mobil DTE24 hydro oil, still un-opened. I was told I need to watch what hydraulic oil goes in to make sure I don't burn up my pump. I am not sure what to look for to verify this will work in my M62. Anyone able to offer assistance?
dragonwagon
west branch Mi
Been in towing 35 years . hour hyd sytems are not fussy on what type or brand of hyd fluid used . The weight of the oil is probable the main issue . ISO 32 is a very common weight . Higher or lower is fine as long as its not way up or down the scale .
Light oil is used for cold weater , heveier in warmer climates . Many tractors , loaders and so on are much more specific in what hyd oil is used as it is often shared with the trans and other components .
gimpyrobb
27,785
748
Cincy Ohio
Thanks guys, sounds like my wrecker's hydraulic oil will get swapped out for new in the next few days! Wonder how much is left with all those hoses I blew out.
runk
65
Houston, TX
Before you start pumping it in, take some of the old and some on the new and mix it in a clear cup, make sure it mixes. With a quick look, this looks like a standard hydrocarbon base oil, and I assume the old oil in the wrecker is as well, but mixing them is a quick check for incompatible oils. Some of the newer "environmentally friendly" oils have other bases and form this really nasty snot when you mix them with the older oils. There used to be an issue with hose types, but if you've replaced most of the hoses that shouldn't be an issue.
gimpyrobb
27,785
748
Cincy Ohio
Thanks runk, everything I have put in has been HC base oil too, but I willcertainly check before re-filling.
wdbtchr
St. Louis, MO
Most of the hydraulic oils like Case TCH just have higher levels of anti-foam agents for the torque converters. Shouldn't hurt a thing.:beer:Good score!
m16ty
211
Dickson,TN
The wrecker hyd is a simple system. Just about any hyd oil will work. I'd use it if it were mine.
swbradley1
Modertator
1,602
Dayton, OH
Yep, when I got my backhoe they had replaced it with ATF. Now I'm switching it back.
