Hydraulic system
Givinup
Oklahoma City
Is the hydraulic system on the m1088a1 an open or closed system.
I need to remove the spare tie hydraulic jack and am wondering if I need to be prepared for a few gallons to leak out, or the entire system. Likewise, I need to learn how to refill it and close it back up.
I can't seem to find the hydraulic reservoir/fill. Unless it's taking off the hydraulic to air unit cover.
Sent from my SM-G955U using Tapatalk
Scott z
26
Houston, TX
I have the same questions as the op. I don't see a reservoir either. (2003 m1078-a1). I've looked behind the cab where the original manual shows it should be and I don't see anything on either side.
NDT
6,487
Camp Wood/LC, TX
Its in the middle, under the decontamination bracket. Has a knurled screw for the filler.
Awesomeness
1,518
Orlando, FL
No, like Suprman said, it has a little knurled knob on the top of it that is the fill port / dipstick.
tennmogger
542
Greenback, TN
Its a closed system, based on what I think you are asking. If the valve for the subsystem you are dismantling, like the tire lift, is closed, no oil will leak out except that in the hoses and cylinder of that subsystem. Plugging is still a good idea so a misplaced valve position does not dump oil accidentally.
Givinup
Oklahoma City
Great info, thank you. That's the plan, but I'll plug anyways.
Checked the hydraulic reservoir and it's way below the refill line. The hydraulic jack is the only think leaking to my knowledge, but I'll refill and check after plugging the jack. Appreciate the suggestions.
Givinup
Oklahoma City
Checked out my hydraulic pump reservoir yesterday, turns out it's really low. Upon removing the spare tire jack (that was leaking) what's the beat way to bleed the hydraulic system of air (on the hydraulic side)?
Can I fill up the reservoir with the knurled nut off, or should I fill in stages and run the cab jack to circulate the new hydro fluid in, stop and repeat?
Awesomeness
1,518
Orlando, FL
I think it's self bleeding. Did you check the manual, in sections related to something like changing the cab hydraulic cylinder or the pump, to see what it says? You'll find that the manuals are amazingly detailed so that even the greenest of mechanics can perform the work (e.g. it will tell you to take a bolt out, remove a part, and then to store the bolt back in the hole [until you get to the section to replace the part]).
Givinup
Oklahoma City
I haven't yet. The manual I have isn't searchable, and the only medium I have to view it is on my phone (no access from work or home), so it makes viewing the manual somewhat cumbersome. I can certainly use it, it just takes longer usually for quick answers.
porkysplace
1,493
mid- michigan
Well you could always stop by your local library are print that section of the TM off.
