Hydro boost leak - vent tube?
36
13
boise, id
In case it helps anyone having a similar issue, I jacked up the front wheels and performed the bleeding procedure, with the reservoir cap off, and with the engine running. It made a bit of a mess, but fixed it. Despite doing the bleeding process twice with the engine off, there must have had still air in it.
Coug
4,841
Olympia/WA
I had to bleed mine the same way. Left the cap off, filled to overflow, turn the wheels back and forth a few times, then refill, turn it on, turn the wheels, and put the cap on and called it good.
