hydro flow and psi on m936a2
simp5782
Feo, Fuerte y Formal
9,368
Mason, TN
Its 2500 psi listed on page 1. It also says no-one has done the flow rate. It may be in the TMs. Its something like 45hp so that would be 32gpm. Which sounds right for a 100gallon tank.
Sent from my SM-G935P using Tapatalk
sweetk30
horseheads,ny 14845
ya but is this the whole system or just the boom winch for flow . ?
i understand the 2500 psi . but trying to check flow rate to see if stuff is working as it should .
red
25
Eagle Mountain/Utah
The pump on the transmission (for the front winch) is 35gpm, the one for the crane is much bigger.
We know the tcase PTO turns at 1:1, the m936a2 operates at 1500rpm, and max PSI is 2500. If the 16.5 cubic inch per rotation of the crane pump is correct, then it's 107gpm.
