Hydro tank
bigred350
stratford/CT
Hi there does anyone know if the hydro tank behind the cab on the m932 is the same as the tank on the side of the m925?
dilligaf13
south, florida
The reservoir tanks are similar. The M925 hydraulic talk has mounting flanges on its base and the vertical portion of the tank whereas the M932 only has mounting hardware on its base. I also believe the return lines are on opposite sides of the two different tanks, if memory serves me correctly.
M925 hydraulic reservoir
M932 hydraulic reservoir
bigred350
stratford/CT
Thank you that is exactly what i needed to know! Does anybody have a Hydro tank with mounting bracket and lines for an m925a2 they would like to sell?
M35A2-AZ
388
Tonopah, AZ
I looked at my M932A2 and M925, It looks to be about the same, I think you could get it to work. Like what dilligef13 said about the mounts.
bigred350
stratford/CT
I cant seem to find anything does anybody have a part/serial# for the hydro tank and bracket for the m925 or direct me to a place to look it up?
dilligaf13
south, florida
It's listed in the TM
2590-01-085-5352 12257126 19207 RESERVOIR ASSEMBLY EA
NSN# 2590-01-085-5352
Part# 12257126
FSCM
19207
Description RESERVOIR ASSEMBLY EA
bigred350
stratford/CT
Thats great thank you. I'm buying a winch from a m932 for my m923 but the tank and bracket are different so i need a tank and bracket from a m925 for my m923. dave at eastern surplus my have what i need but he needed an NSN# to look it up. so the tank and bracket are covered under one NSN#?
