- 83
- 11
- 8
- shelton/CT
Hi there has anyone run into this problem installing a winch on my 923a2 everything came off an 932a2 the bracket for the hydro valve doesnt fit in the holes my top hole is 4 1/8" down from bottom of frame rail.ill put up some pics later but even the bracket for the cable seems to be wrong too. I have the large battery box on that side are those brackets different? can someone else measure from the bottom of the frame rail to there top bolt on the valve bracket thank you
