HydroBoost Question
231
Mount Laurel NJ
Hey all, I am planning to swap out the engine to my cucv (cummins 12V) but I am asking this question here because all I would like to know is which lines are high pressure and low pressure lines on the hydroboost AND power steering box? I need to figure out the plumping, but I could not find any straight forward diagrams of the system. Any help would be greatly appreciated.
231
Mount Laurel NJ
Cummins Swap Hydroboost Questions
To those of you that have swapped a 6bt into a CUCV or any other GM truck with hydroboost, I have a couple questions...
1) There are 3 ports on the back of the power steering pump for the cummins. Did you use all 3? Which is the high pressure and which two are the return lines?
2) Does the CUCV in stock form use two returns in the GM power steering pump or was there only 1 return and 1 outlet?
3) If you have a picture, is there a way I could see labels on which line was high pressure and which was a return?
4) Will the cummins 6bt power steering pump push enough fluid for the system safely?
Thanks so much!
gringeltaube
Staff Member
2,479
Montevideo/Uruguay
TM 9-2320-289-20, 8-28. Lines 9 and 18 are high-pressure; hoses 10 and 15 are low-pressure.
Jozseph
New York
FWIW review the following;
http://flashoffroad.com/Maintenance/PowerSteering/powersteering.htm
