I could use some input on rear bumpers...
Kane
Kane County, Illinois
I have tried looking into this on my own, but it appears I don't have all the information. Basically I'm looking to add a rear bumper to my M1025. Here is what I'm starting with:
What all do I need to track down in order to mount a rear bumper?
Thanks everyone!
Retiredwarhorses
3,874
Brentwood, Calif
Bumper, 2 outer, 2 inner frame brackets, 4 shim plates, 2 inner brackets that un from the bumper pintle to the frame and if you like but not required, 2 outer long brackets....look in the TM 24P, it shows everything you need and part numbers.
alot of stuff is on eBay.....also, PM 86humv on this board, he has everything you need...his name is Greg.
emmado22
138
Mid Hudson Valley NY
There are 2 almost the same, but they are different airdrop bumpers. The "old school one" that has the U shackles and the newer "A2 teardrop" style shackles. If you want to save yourself a lot of heartache and searching, find a complete one with all the correct brackets. Some of the brackets are the same for both style bumpers, some aren't, but can be made to work. trying to ID them can be a PITA. As stated, the TM 24P will guide you thru this, complete with pics and part #'s. I added the A2 style rear bumper to my M998, along with from A2 style teardrop tie downs, AND kept the old school angle iron brushguard. Check these 2 threads on the G503.com http://g503.com/forums/viewtopic.php?f=63&t=219607 Old school uses U shackles http://g503.com/forums/viewtopic.php?f=63&t=219614 new A2 style with teardrops.
