I finally did it
mikeroot2
Argentine/Michigan
I just converted my primary/secondary fuel and oil filters last weekend. Got oil kit from westfolk and fuel from Jatonka(decided to spread the wealth). Both kits fit/worked perfect. Definetly a worth while mod(IMO).
Kohburn
SOMD
Can someone explain more about this to me?
it's a kit that lets you use common spin on filters with check valves instead of the the stock inserts.
its cheaper/easier to get a filter when you need one, and the check valves help provide you wil oil pressure faster on startup.
